Hood for Canon 25/3.5?
I never found one for my 25mm.
just a Canon thin UV filter is all I use and I do not find this lens to be really flare prone.
No hood needed. Although,on my R-D1 I use the 12585 Leica Hood to minimise flaring. But I think the flaring of this lens on the R-D1 may be caused by sensor reflection. As soon as I have the camera back I will test if removing the rear flat piece of glass makes a difference.
How are you able to mount the 12585 on a Canon 25/3.5?
Are you joking about removing the rear lens element to see if it reduces flare???
I can mount the hood on the UV filter rim. I only take the filter off in very low light, to avoid ghosting. No, I am not kidding about the rear glass test. It is simply screwed on and it may just add to sensor flare. I don't think the 'float' glass adds anything optically except protection. Any defect on the rear lens will definetely affect the image.
Thanks for the replies. I guess the flare I sometimes see results from bright light sources in the frame, where a hood wouldn't really help.
You're right CanonRFinder -- the lens barrel does shade the front element pretty well, like with the Canon 28/35.
the flat back element is probably for better handling. It makes the lens longer and allows easier focussing and aperture setting.
Compare it with the Nikkor 25/ f4 with the same basical design but misses the flat element
