Hood for Canon 50/1.4?
CZeni
DaDa is everywhere.
4:01 AM
My Google-Fu is weak and I cannot find the answer to this on the web. Anybody know?
Thanks...
i assume you're asking about which hood fits on that lens?
it's the canon s-50.
kevincameras has 2, one for 50 & another with case & box for 85 bucks.
they show up on ebay sometimes.
joe
joe
Perfect - thanks!
and i won another of these hoods, so now i have a spare.
but it's not nearly as nice as the one i got from you victor.
guess which one i'm using?
joe
Hmm. I wonder how the length of the S-50 compares to the hood I have. It's labeled "Series VII Canon Lens 50mm F:1.5"
Now this hood came attached to an 85/1.9. It fits on a 50mm outer-diameter lens, not a 42mm one, which means it actually won't fit on the labeled 50/1.5 (which uses 40mm threads, 42mm outer diameter). However, it seems to be a perfect fit for the 50/1.4. Why is it labeled 50/1.5 then?
Scott
someone changed the adapter.
the hood for the 50/1.5 has a 42mm clamp on adapter.
there's a pic on kevincameras site.
joe
I think Joe has it right. The hood is for the 1.5 but the adaptor was changed. Now, this brings up an interesting point because I have an adaptor ring that will fit the 1.4, I wonder if one of my hoods will screw into it.
Now I have a mission this morning. Thanks for the idea.
The S-50 is the official hood, but any generic 48mm screw-in hood will do just as well (I have an S-50, but use a 48mm screw-in for general use as it's more secure).
The Canon 50mm/1.4 takes 48mm filters. You may be able to find a third party lens hood in the 48mm size.
If not, put a 48/49mm filter thread adapter on the lens and use one the quite common 49mm lens hoods.
The "Filter Connection" has quite a selection of sizes and good prices:
http://www.2filter.com/
The Filter Connection is a nice place. Just a few towns over from me. It is not a store, just an office with lots of supply. I popped in to pick up a couple items and was treated very well. Real people behind an e-business, not a faceless warehouse.
Oh, I use a 48mm collapsible rubber hood right now on my 50/1.4. A real cheap solution.
