jusxusfanatic
Hoods that fit the Summaron 35/3.5 LTM
I only found 3 that are around that price range :
12571J
ITDOO
FOOKH
Any more? Thanks
12571J
ITDOO
FOOKH
Any more? Thanks
madNbad
The FOOKH is the correct hood. It's the clamp on style and you can use it with an A36 filter without any vignetting.
Richard G
FISON works just fine. Doubles for my Elmar 3.5s and the Summaron.
a.noctilux
FIKUS fully collapsed to no number ...
if you don't mind the weigth
http://www.l-camera-forum.com/leica-wiki.en/index.php/FIKUS
could be used for your other lenses 5cm to 13.5cm
dufffader
Leicanaut/Nikonaut...
There are two versions of the Summaron 3.5. I assume you're referring to the earlier A36 version. Then I believe the FOOKH is the right one.
I always thought that ITDOO is for the later E39 version of the Summaron along with the IROOA.
jusxusfanatic
Ohh yea forgot to mention! Its the earlier version a36. So I'm guessing the fookh, fison and the fikus works right?
peterm1
Yes I believe that is so. I also found a cute little hood for this type of lens which normally takes a clamp fit hood (including the Summar f2 and the Elmar f3.5). This hood is in the form of a piece of thin spring metal which is circular in shape just like a hood. It is slit down one side. Pressing the two little tabs on the hood open it so it can be slipped onto the lens and when you release the tabs the thing clamps shut around the perimeter of the lens. Kind of cute and looks very 1930s. In addition Walz made some after market hoods for these lenses back in the day.
jusxusfanatic
Alright, thanks guys!
jusxusfanatic
Really? The FIKUS works?
So, FOOKH works
ITDOO doesn't
FIKUS, really?
FISON works right?
So, FOOKH works
ITDOO doesn't
FIKUS, really?
FISON works right?
