How I got a Minolta Scan Multi (SCSI) working under Win 7 64bit!
wojtek
5:12 AM
Hey guys
I got this scanner from my friend some time ago - a great, but old Minolta Scan Multi (not Multi Pro, sadly). It worked well with Windows XP, but - since I run Windows 7 - I needed another machine to run it on. It's old SCSI controller, Adaptec AHA2930CU wasn't working with 64bit version of Win 7.
Until I performed some crazy mumbo-jumbo, that is.
I found the emulated drivers for Adaptec AIC7870. It's the chip that this card uses. And, after installing these drivers (which weren't signed for Windows 7, of course), I got my Minolta to work with VueScan! :D
Here's the proof:
This crappy picture of a bike I have taken long time ago with an Agfa Isola (or something like that) camera.
I just scanned it 10 minutes ago.
Therefore, if you want your old SCSI Minolta scanner to work under Windows 7 64bit - fear not, as it probably can! :D
Here are the drivers should anyone need them:
http://dl.dropbox.com/u/18370125/Drivers/adaptec_legacy_win7x64.zip
Enjoy!
Cheers
Wojtek
P.S. I take no responsibility if anything goes wrong. But I encourage you to try it!
Quite interesting I'd say, because that scanner has tabletop dimensions but it can scan 6x9 at close to 1200 dpi and 12-bit. And it's particularly good with slides, IIRC. Which those it does provide rather decent scans!
The Scan Multi does a great job but it doesn't have digital Ice. So scratches and dust have to be manually removed - before scanning as much as possible.
I guess I should clarify that I'm saying thanks for the SCSI fix. I'm using a Nikon LS-2000 because of the file provided by wojtek.
