L David Tomei
- Local time
- 12:06 AM
- Joined
- Dec 3, 2007
- Messages
- 363
I had worked on digital imaging development some 20 years ago when we first began capturing 4096 x 4096 x 12 bit images, which were considered to be, and still are, big images. The purpose then was to retain high resolution over relatively wide fields.
Today, I see that the number of pixels captured by digital cameras can be very large, perhaps too large when the purpose is to display an image on screen or to produce a print of reasonable size, e.g. 11 x 14. In such cases, much of an image is discarded after the software has recalculated the value of a final pixel based upon the neighboring pixels. If not, then the raw images of 16 million pixels or more, each with well over 1000 digital values, are too big to display and take a lot up of memory.
Unless one needs the option to zoom in and crop an image, there is a practical limit to the need for increased pixel numbers.
I curious, How many pixels are considered to be sufficient for non-technical photography?
