Leica LTM How tight should the aperture ring on a 5cm Elmar be ?
Moto Mark
10:42 PM
When I change the aperture ring on my 5cm Red Scale Elmar I have to hold the outer ring with one hand and use the fingernail on the other hand to turn the aperture ring.
It has a lot of resistance on the ring, is this normal ?
In mine, the focusing ring rotates very smoothly but the aperture ring has some resistance to it but not too much. I always thought that it feels fine.
When the aperture is turned, the barrel should not move. Sometimes a very little bit of sewing machine oil helps. If not, the lens must be professionally cleaned.
Erik.
Thanks Victor, it was that same video that got me thinking I might have the same issue.
At best I’d try Erik’s suggestion and use sewing machine oil but that’s as far as I’m capable of going.
