How to adjust an Industar 61 LD to focus with an M8
eleskin
3:26 PM
I know that the Russian lenses are set to focus for the Contax, and Have noticed a slight shift in focus with all of my Russian lenses. Not a big deal in that if I turn my focus ring to the right slightly, everything is sharp. It seems for the M8, the lens elements have to be a little farther from the sensor than the rangefinder indicates. I am wondering how difficult would it be to adjust my lenses to focus correctly. I have had my Industar 61 LD apart for a lube job, and it seems this lens is simple to assemble. Any thoughts would be helpful.
An I-61 L/D (LTM) ought to focus correctly on an M8 without any adjustment. Have you found, by taking photographs with it, that it does not focus correctly?
