how to clean the viewfinder??
utku
Utku KAYNAR
1:08 AM
how can I clean the vf on my GSN ??
is there a permanent damage that must be calculated before opening the vf ?
any answers appreciated.
regards,
If you mean the outside, clean it just like a lens. I use a little cleaning fluid on a Q-Tip to get inside the eyepiece.
If you mean inside, this requires removing the top cover of the camera. You can use lens tissue and a Q-Tip with a little (very little!) cleaning fluid for this. Be very careful of the mirror as it is a front surface mirror and very easily scratched. Less is more!
If you go lightly, you shouldn't mess up the alignment. 😎
P.S. By cleaning fluid, I mean lens cleaning fluid. I like Kodak alcohol free. I find it cleans well and has less problem with streaking.
