How to convert Panasonic Raw into something useful
Tuolumne
11:17 AM
Does anyone know how to convert Panasonic raw format into some other more useful raw format that can be used with something besides SilkyPix? How many damned post-processors do I need to learn to shoot raw formats from different manufacturers? Grrr...
/T
No, it's lossless and will let you use earlier (dng compatible) versions of acr/lr to process files
Some people convert everything to dng and throw away the originals. I don't because DXo doesn't recognise dng yet - it's french and plows an independent and delightful furrow of it's own
Mike
it's called lossless but you actually lose minor detail while converting raw to dng.
The pros: compatible with LR,PS (adobe product), the file size will dramatically decrease.
The cons: not every software supports dng (ofcourse...); who knows what's gonna happen in 10 years? dng might become the dominant file type or it will vanish which will give you major headache later on.
I save all my raws (untouched) and also convert them into dng for post-modification.
You shouldn't lose any detail - all they have to do is copy a set of numbers into a file format the raw converter can read. There's no interpolation going on. The colour balance may be messed up if the embedded colour coords are wrong, but that's not a detail issue. I was given to believe that the compression was lossless, so it would be interesting to understand where detail loss can occur.
I too save all my raws in original form, but that's also to be free of Adobe's hegemony
Mike
