Lauffray
Invisible Cities
DominikDUK
Split grade printing grade 5 for a short time to get good dark tones and the rest of the exposure around grade 1 1/2 to 2. Selenium toning also helps to give you a decent contrast. selective bleaching as chikne might help as well but it should be done as an additional step to the other tools available like split grade.
good luck
good luck
pesphoto
try preflashing the paper before you expose to reduce overall contrast, this way you expose more for the darker table and the pre flash helps bring down the highlights...
zauhar
I'm trying to print this, though this is is a negative scan and the print is more contrasty.
When I dodge the table in the lower half, I get some shadow details but the writing isn't exposed enough and when the writing is well exposed the table has very little shadow detail.
When you say the letters are not 'exposed enough' I am assuming you mean they don't show up as well against the lighter background produced by the dodging?
This would be a little work, but after making your base exposure (either using split grade as suggested or dodging) use a card with a small hole and burn around the letters, to make them more distinct against the lighter background.
Randy
Lauffray
Invisible Cities
Well compared to the test print with no filter, the letters aren't white, just very light grey and there's a little grain on their edges. When I print with the filter and dodge them, they're just white.
zauhar
Your test print can be made with a filter, you should be testing for optimal exposure with your test print/strips. Sounds like you have multiple variables in play!
BillBingham2
Registered User
Crazy but you might print a slightly smaller print and do cut out for burning and dodging.
Hard one to do in the analog world but a fun challenge.
Can you scan some of the tries and share so we can all learn?
Thanks and best of luck.
B2
B2
DNG
Film Friendly
B2
best way.. but time consuming....
Lauffray
Invisible Cities
Can you tell me more about how this works ? The grade 5 gently sets in the shadows and barely exposes the highlights ?
Lauffray
Invisible Cities
B2
Will do when I get home ! Hope the scanner is big enough
Lauffray
Invisible Cities
Truth be told it was more about remembering/experimenting as I pick up printing again, rather than to produce a good print. So yes I may have my tests all over the place
Lauffray
Invisible Cities
Black mat?
How does it work ?
I already have printable versions made with PS, I want to know how to do it in the darkroom
Dwig
You might consider "silver masking". This is a technique that was generally used for printing color transparencies, but can be used for B&W negatives.
In the linked tutorial, simply keep in mind that the negative of a negative is a positive. The masking film will be a weak positive when using the technique with B&W negs instead of the weak negative the is used when reversal printing color transparencies.
http://www.bonavolta.ch/hobby/en/photo/masking101.htm
Lauffray
Invisible Cities
zauhar
Here's a side by side comparison of the prints. The one on the left is without filter, looks pretty even to me. The one with the abysmal burning on the right is done with grade 4 filter.
Also, what's up with the tiny upload sizes, 500x500 ? :bang:
Maybe try 2 1/2 and just burn right around the lettering?
Nice to see that I am not the only one who makes print .... after print ... after print ... ;-)
Randy
P.S. Did you try the previous suggestion to do it split grade? Part of the time at grade 0 and part at grade 4 or 5 (try 50/50 for initial test)
Lauffray
Invisible Cities
Yes I did, what a huge difference ! Takes longer to test and get your times right, but there's a huge improvement. I'll post some examples soon !
Freakscene
Obscure member
Dye dodging is useful for this type of scenario and makes negatives where you can easily produce identical prints rather than having to learn a complicated set of dodge and burn procedures. For commercial clients where they had a very popular print that needed to be printed at the very highest standard I sometimes used unsharp masking (referred to above as "silver masking") with some dye dodging on the mask. Make the print overall slightly darker and bleach a little, adding selectively where needed (remembering that bleaching adds more highlight than shadow contrast).
Marty
Marty
Lauffray
Invisible Cities
... I sometimes used unsharp masking (referred to above as "silver masking") with some dye dodging on the mask.
Holy F that's some process !
Lauffray
Invisible Cities
... I sometimes used unsharp masking (referred to above as "silver masking") with some dye dodging on the mask. Make the print overall slightly darker and bleach a little, adding selectively where needed (remembering that bleaching adds more highlight than shadow contrast).y
Would this still be relevant if I use multigrade paper though ?
Freakscene
Obscure member
Holy F that's some process !![]()
Indeed. I had some demanding clients, and some of them had some pretty terrible negs. Heroics are usually only required where a photo is great and the neg is bad, or the situation it was shot in was difficult to impossible.
Yes, absolutely. It lowers the overall contrast, allowing you to print at a higher contrast grade, increasing local contrast. There is also no reason not to dodge and burn (traditionally or with dye) while printing the neg sandwiched with the mask.
Marty
