HP5, Delta 400, XP2, Kentmere 400???
crave1ne
8:02 PM
I'll start by saying this... I'm not a fan of HP5... I enjoy FP4 quite a bit from Ilford, and would like some direction with the other 400 speed films they offer. I do my own developing and printing at home. So the XP2 is probably out of the question for now. But I'm curious as to what other's think about these films and how they vary from one another. Please feel free to share your opinions and photos here...
What don’t you like about hp5? I’ve personally found it to be the most diverse film I use. Regarding the other films. Kentmere and ultrafine 400 are both reasonable budget alternatives and dry perfectly flat for scanning. I don’t think either are THAT much different from hp5 though tbh. There’s been comments on the grain structure etc, but both are really good value. It could also be your developer or times need adjusting. I think you will get more specific answers if you explain what you don’t like about hp5 though. I’ll post some photos on ultrafine and Kentmere 400s with developer info later.
Idk, there is just something about hp5 that I'm not that into. It seems to "soft" maybe.. I like more contrast and have not been successful with using it i guess...
I also am not a fan of HP5. If find it kind of flat.
I use a lot of Kentmere 400 in Xtol, and it reminds me of the old Tri-X. A bit more grain, perhaps. The price is right.
For what it's worth, I've always felt that slightly flat negatives are preferable to contrasty ones. There is more detail in flatter negatives, and they print (and definitely scan) more easily than contrasty ones. You can always add contrast to an image when printing in the darkroom or digital rendering, but you can't add detail that isn't there on the negative.
That said, it's really a question of matching your film to the right soup for the look you are after. I always suggest it's best to settle on a film stock you can get easily and tweak the results with your choices about developer and technique. Any film can give very different results when handled differently, and it can take a lot of testing to find the combination that gives you exactly what you are after; but most films are capable of beautiful results once you dial in your exposure and developing regimen.
HC110 here, only because I haven't used a half of a bottle yet. I'll give Kentmere a Try. Fomapan looks interesting, but feel it can sometimes look soft as well.
You have very valid points. I just recently got into film and using a darkroom. I'll take what you said here and find a film that I enjoy the price tag. And then start experimenting with the soups
Kentmere doesn't really have more contrast than HP5 if anything it is even flatter also some people don't like the Kentmere's grain. Fomapan on the other hand is rather contrasty and far from flat but grainy and not really an ISO 400 film in most developers. Delta 400 has more punch than HP5 also less grain but can be less forgiving than HP5 still a lovely film. As other posters have said you can always add contrast, another way to increase contrast with hp5 is to push it a stop to E.I. 800.
I have read alot about pushing... so you push it to 800 and develop it alittle longer... it doesn't make sense to me how it give it more contrast...in my mind adding to the dev time would then still expose it as normal?
Pushing the film adds contrast you lose some midtone and some shadow detail. Very simplified the film isn't really faster you just develop it a bit longer which increases the contrast, the shadows will lose detail as you basically underexpose the film by a stop, the longer development time will blow out some highlight and midtone detail, hence an increase in contrast. Contrastier film usually have less mid tones and somewhat less detail in the highlights and shadows Tri-X is a good example beautiful film but a lot less midtones than HP5+.
BTW Another way to increase contrast is to develop the film a bit longer 5% to 10% without actually changing the film speed.
I'm not a fan of HP5 either. I much prefer Kentmere 400 to it. There is something more pleasing about the grain of Kentmere, though it may technically be 'grainier' it feels less 'clumpy' to me. I wish they made it in 120. I primarily develop in Rodinal 1:50, but even in other developers I don't prefer HP5 over Kentmere 400 or Tri-X.
You can get it at the printing stage. With split grade printing for example or and or a certain amount of dodging and burning.
I actually LOVE HP5 with HC-110 (Dil B or Dil H), but my post dev workflow is digital so I try to optimize dev for the specific intent of scanning.
I'm looking more for high contrast in shadows, low contrast in highlights... I might be asking to much here
Yeah, reading this I would suggest you REALLY don't want to/can't achieve that in your negatives- but you definitely can achieve it in rendering your images into positive, whether in the wet darkroom or the digital one. Go for flatter negatives and preserve your highlight details.
Important basic that should be well understood:
Shadow density is created at the exposure, highlight density is created during development.
This happens because the highlights build and get thicker the longer they are in contact with active developer. The shadows will not change much from more development time.
I’m in the camp of getting as much information into a negative as possible, then using my vision for the shot to determine how much contrast to add etc
If you are coming from digital, consider what happens if you overexpose and clip the highlights, there is NOTHING that can be done to recover them in post. The information simply does not exist. This is why the histogram is important to keep in mind while using digital. In film the OPPOSITE is true. If you UNDEREXPOSE, the film simply does not have the shadow information and no amount of development will recover it.
This is where the term “overexpose, underdevelop” comes from. You overexpose to guarantee shadow detail, but underdevelop to restrain the highlights. This will give you full tonal range in the negative and provide many opportunities in the dark room or Lightroom.
Try this (assuming 400 speed film)
On a normal sunny day, set your camera meter to 200, cut development by 20%
On a REALLY bright day or snow/sand etc, etc meter to 160, cut development by 30%
If contrast is low like lots of clouds or overcast, kept it at box speed and develop as normal.
If you MUST push the film, you lose shadow detail because you are underexposing, but by extending development, it brings up the highlights to make an acceptable image.
Delta is flat and boring to me. I have M9 for BW like this.
FP4 is lovely, but K100 is good as well.
HP5+ is now luxury priced film for me. I push it all way to 3200.
K400 isn't worst at box speed and I used it a lot and under different names.
I only bulk load, develop, scan or print at home.
I haven't used hc110, but a lot of hp5 and rodinal 1+25 will give you grittier negatives at box speed, more so pushed to 800.
As Ccopola82 points out, you can control everything within limits using exposure and development. You can achieve high shadow contrast and moderate highlight contrast, and negatives like this are pretty much perfect for wet printing. All negative-positive media have lower apparent shadow contrast than a lot of people’s eyes perceive, and this approach compensates at least partially. Take a 400 speed film, shoot at 200 or 250, and develop to moderate contrast. It’s not hard.
Marty
Thank you for this reply.. I think this is what I was needing... I have one camera that I can select ISO. When I'm doing this with my other camera's without light meters and selecting ISO. Should I still stick with Sunny 16 at these different speeds?
using 400 speed film...
your example on a normal sunny day rate it at speed 200.... Id set my shutter for 1/250 and adjust aperture as needed with sunny 16.. then when developing, adjust time by 20%?
