I can not post?
optikhit
Photo gear player
6:11 AM
Harbin, China
I find this FED collapsible lens with a weird series of numbers as the aperture numbers, 3.5, 4.5, 6.3, 9, 12.5, 18. Any body know this lens? What is the difference with other collapsible lens, say industar 22/50? Can this lens fit my Fed 2d camera?
Thanks a lot.
Thanks a lot.
It is indeed an older version of the Industar-10 - an uncoated elmar copy like the very earliest I-22s. Unfortunately it may not be compatible with the FED 2. Lenses with these aperture numbers were issued on FED 1s made from 1934 to c.1948. Once large-scale production recommenced in 1948/49 lenses had the "normal" modern aperture sequence. More importantly, they were produced with a standard Leica-screw.
I believe that earlier lenses generally do not fit later cameras, or - if they do - produce out of focus images; the screws were cut to a slightly different standard. I may be wrong here, but I think that Leitz used a Whitworth 39mm screw as opposed to the DIN screw mistakenly used by the Soviets. But... Best to try a test film!
Best wishes, Ian
