I really like the SP
taldinar
8:51 AM
This is only my second posting here on RFF.
A couple of months ago I bought a 35sp after using digital for the most of my photographic "career". Now I have exposed some rolls of T-max and I must say that it is a completely different experience from my d300. I like the suspence of having to wait for results, not chimping and the excitement of seeing if developing it was successfull. Developing was much easier than i expected and I am very happy with the results. Digital bw conversions cannot compare.
Here are a couple of samples:
Audun
Thank you.
The olympus 35sp is a fixed lense rangefinder made in the 70's. It's about the same size as a leica M and has a wonderful 42mm f1.7 lense. It is acceptably sharp at 1,7 and pics up to very good around f2.8 and above. Construction is almost all metal and it has centre wighted and spot metering, although I never use it.
Here is a link: http://www.cameraquest.com/olysp.htm
Audun
If I had to keep only one film camera, it would be my Oly 35SP. It is just nice to use, has a great lens and delivers more than I have a right to expect from anything 40 years old.
Eventually everyone falls in love with the 35SP. :D
Currently I have one of mine set on auto exposure. I've made a few AE exposures in the past, but I decided to shoot most of a roll on AE. I think it's a pretty accurate system, and I use spot metering a lot.
I adore my SP, considering taking it to my wedding gig along with the Nikon.
I will be taking mine to a family wedding at the end of the month, along with an OM-1n + 50/1.4 and maybe 28/2.8. I might take the 5050 digi too, I dunno. Film will be TMY-2 and Neopan 1600.
Audun, your shots are great.
Actually I find it easy to use the digisix wich operates with the same numbers. I just find it hard to trust the build in since it differs up to 2ev steps from the insident metering I get with the digisix. It may be that neither is absolutely correct and I would have gotten equally good/bad exposures with the build in meter given the latitude of t-max. It may also be that it is not calibrated to the voltage of the battery (it came with an adapter and new type battery). I haven't explored it too much since I have the external one and find it easy and accurate to use.
Do you guys use the build in spot meter in low light? Do you find it accurate.
Newer alkaline batteries can be a problem. Zinc air 1.4v hearing aid batteries with some sort of spacer are probably better.
One of my SPs has been circuit-modified to silver 357 type batteries , the other two not. For the latter I use zinc-air with a #9 o-ring, which works perfectly. NEVER use an alkaline battery in an SP or OM-1.
I had my 35SP adjusted for alkaline batteries and have used it successfully for several years. Current drain is so low that the voltage drop does not really matter, it is enough to change the battery once a year.
If you use a new alkaline in a SP adjusted for mercury batteries, just up ISO by 2 stops.
:) Thanks to will, and everybody else who commented on the pics. You're right John, about kids and pets. They are good, and readily available subjects, but they have a tendency to cloud my judgement. I am never really sure if I like the shot because of the shot itself or my emotional attachement to the subject.
olympus 35-sp
olympus 35-sp
Just got a new 35sp... wow what a cool lens. nice camera.. can't wait to use her.What is the zinc air battery i need with an o ring?..thanks
A couple of months ago I bought a 35sp after using digital for the most of my photographic "career". I like the suspence of having to wait for results, not chimping and the excitement of seeing if developing it was successfull.
Audun
My family makes fun of me but I also love the suspense of waiting to get the film developed. I just developed some B&W that I probably shot about a decade ago. It was like opening a time capsule. I shoot a lot of B&W and frequently forget to develop rolls for years. It's great developing them, brings back the memories like it was yesterday. I hate the immediate results of digital, there is no fun to it.
