Nomad Z
The vertical motion of the rewind knob on my IIIf is rather loose - it has a tendency to drop when I'm rewinding, and to lift when the camera is upside down for loading (or when I'm putting it in the bag, etc). It doesn't affect the functioning, but is a little annoying, and requires me to handle the camera in such a way as to stop it doing its own thing.
According to the Leitz service manual, this shaft should be lubricated with something called No. 300 (the symbol is three circles with the top-right quadrants filled in black), but there is no indication of what that actually is. I assume it's grease of some sort, and is intended to introduce a little drag to keep the shaft in the up or down position as required, but can anyone confirm this? Does the rewind knob on your Barnack have some drag when you raise and lower it? If so, are there traces of grease on the shaft that slides in the little chrome collar?
