Leica LTM IIIG Service
Rhodie
3:06 AM
Can anyone advise on who I can send my IIIG to for servicing?
When I load correctly the film is not wound on, tho the counter moves & shutter fires.
Is there anyone in South East Asia who can do a good job?
Cheers
Rhodie
Bangkok
Cheers
Rhodie
Bangkok
Rhodie, can you be a little more descriptive about your camera problem? Perhaps you are still not loading the film properly even though you think you are. Take the bottom off, remove the take-up spool and then wind and fire the shutter. Do you see the sprocket teeth turning, and the take-up spool shaft turning? If yes, then you are not properly securing the film end in the take-up spool when loading. If no, you do have a problem beyond my understanding. Tell us more how the camera is acting when you wind and fire the shutter. Maybe someone can help.
Regards, Paul C.
Paul
On your recommendation I persevered one more time before sending it out to Oleg in the Ukraine.:eek:
A sliver of film had broken off, impeding the wind on!
Well, suffice to say, my IIIG is now going to Japan for painting.:D
http://homepage2.nifty.com/Shintaro/top1.html
Your advice was necessary & much appreciated.
Cheers
Rhodie
