ILford MC filter set for B+W darkroom
FrankS
Registered User
4:58 PM
Does anyone have a set of Ilford multi-contrast filters for B+W, the kind that fit into enlarger for use with variable contrast B+W paper?
Hmm, this seems to be short on answers... I had to tiptoe through the dusty cobwebs of long-undisturbed memories to arrive at Kodak as the name of my filter set. They're 6 inches square. Each came in a yellow Kodak envelope, and within that, the thin filter material was protected by a white card-stock folder. To fit the filter drawer in the head of my Beseler 23C, I cut the folders and filters down to 5.5" square. Then cut a 5" diameter hole in the center of each folder to form a frame and glued them closed. This was in the late-1960's... they're still in fine condition, but they were used for only about 8 years.
So, there's some non-Ilford filter blather, for what it's worth!
I have both filter sets, the ones that are mounted in a plastic frame and put in front of the lens and the film ones that you can place in a dedicated filter slot in the enlarger head (better!).
