Info on GS645S
brocktopus
9:02 AM
Hello all, i'm new to the forum and new to rangefinders! I have just bought my first rangefinder, a Fuji GS645S. I have not recieved it yet, but it should be in this week or the next week. I am just wondering ,seeing as this is also my first medium format, i am looking for some tips you might have on simple handling of the camera. I am actually most aprehensive about loading and unloading film, a i constantly fear exposing it. Any help is appreciated.
Thanks,
Brock
I'm a happy GS645S owner, its my main camera and has been for a couple of years.
Loading film is pretty straightforward, the instructions in the manual are probably better than I can give. The only pointer is this- when you start winding the roll, with the back still open, apply just a smidge of pressure to the fresh spool to create an extra bit of drag. This will ensure the takeup spool is winding tightly.
That said, I've gotten a poorly wound roll out of the camera exactly once in several hundred rolls, and that was before I began the routine above.
I'm sure you'll be impressed with the lens, it is outstanding, from wide open.
As MicheldeG mentions, the 'rollbar' is there as a stopgap solution to the camera's weakly constructed front end...
Also, you'll find the DOF markings are hopelessly optimistic. I recommend a homemade DOF chart based on 35mm standards for truly sharp images, which is the camera's strongest suit.
Enjoy!
