gtramctram
camaro69
hello. I am new here. I have inherited a ton of Canon equipment. I really don't need this stuff so I am looking for the best way of selling it fairly.
I have a IIIA range finder / 50mm f1.8. very good case.
Canon P w/ f1:1.2. extremely fine case
Canon Pellix w/ 50mm f1:1.4. Mirror is in excellent condition. excellent case
Canon A-1 w/50mm f1:1.4 and case. Excellent
Canon wide angle serenar 35mm f:2.8 w/ range finder and excellent case.
Canon Serenar 135mm f:3.5 w/range finder and excellent case.
Canon 50mm lens case. excellent condition
Canon flash unit B-II
Canon auto-up 40'-22' serenar 50mm f1.8. case is excellent
Canon auto-up II 50mm f1.8. Appears to be in origanl plastic wrap. Excellent case
Canon lens hood for super-canomatic R 100mm f:2. Original box. Appears to have not been used.
Canon 50mm f:1.2 lens case. Excellent .Used very little if any.
Canon self timer II. W/case. excellent condition.
Canon camera holder model L. this shows very little use if any. Case is excellent.
Canon series VT f:1.9 50mm/ f3.5 35mm lens hood. This shows a little use.
Canon range finder w/case. This seems to be an adjustable instrument. It is larger than a regular range finder and has the E P diamond on the front. You can adjust the size of the object in view. I am stumped on this one.
Walz filters for the IIIA w/kenko case. excellent.
Koden light meter w/case. excellent
Walz Coronet B light meter w/ case. excellent
Hansa self timer w/ case. excellent
Canon Rapid Winder. Still in the original box. Appears to have never been used.
All of the above belonged to an excentric uncle. He would purchase items then never use them. It is like a time capsule. All of the above items are in excellent condition. I would wager that a few have never even been used.
Can you good folks offer some advice as to the best way of disposing of these items?
