IR cut filters for M8.2
randomm
4:52 AM
Hi all,
let me start by apologising asking something that has probably been discussed over and over. I just couldn't find an appropriate thread so I thought to ask the kind people here...
I'm looking for IR cut filters for my newly acquired M8.2, and to be honest, am really wondering whether I should pay the premium for B+W filters vs cheaper stuff, like tiny.cc/dn0bbw
I need to get 40.5mm filters, at least two at this point. One for my J3 and the other one to remove glass from and insert into a 40mm filter frame for my Canon 35/2 - I don't think anyone makes IR cut filters with a 40mm thread (I have managed to acquire a number of skylight filters for it and am prepared to smash the glass out of one for this purpose (I have already DIY'd myself one yellow filter for B&W film this way).
With many thanks,
Jani
there are also step-up rings for this purpose (40mm to 40.5mm in you instance) that are very cheap.
As for B+W filters or 'lesser' brands, it is entirely up to you. The B+W MRC have glass that won't contribute to flare or other image degradation that you may run into with some filters. Ultimately up to you to decide what is worth it...
I could never find the 40.5mm ring but do have the 43mm one actually, which is a good point, might be less work that way!
What is tiny.cc/dn0bbw?
40.5mm UV/IR filters can be had here: http://tinyurl.com/3bjhhb7
That link takes one to a page featuring one of those off brand filters that I was asking about.
Those Schneider ones seems pretty expensive to me.
My only gripe with this whole thing is that I'd rather not spend hundreds on filters if the off brand ones do 90% of the same thing as the brand ones do. That's more or less the question. I'm sorry if I wasn't clear...
Just do what I did: wait until someone on RFF puts the filter you want up for sale in the classifieds. It doesn't take long.
...I'd rather not spend hundreds on filters if the off brand ones do 90% of the same thing as the brand ones do...
I have no experience with those filters sorry. I would have ordered one if i'd used the Rokkor 40/2 on my M8.2 but the framelines of the latter don't match well with 40mm lenses unfortunately.
I bought the cheapo-ones off the *bay, lets see if they work. Luckily I have a good test subject: my purple-as-heck-through-M8-sofa.
Cheer the modern consumer economics: filters from Singapore to me in 7 days including a weekend in the middle.
They seem to work fine vis a vis IR cut. I'll report back if I get any nasty reflections etc with them in use.
Can you tell me which one did you get? How much was it?
I have a silver B&W UV/IR 40.5, but I want it in black to match the lens...
My understanding is that b&w MAKES the Leica IR cut filters.
I heard a while back that Marumi makes the Leica branded filters and looking at the chrome filters one would definitely see the similarity. The BW ones are different as they are spec'd as UV/IR 486 cut filters. The glass is a bit different as is the coating. They have a slightly different spectral response but not noticeable in the imagery at all. Marumi filters are identical to the Leica branded ones as far as I can tell.
Phil Forrest
