jpa66
Jan as in "Jan and Dean"
Just wondering if there is any IR film currently being produced that you can shoot at an iso of at least 50. I love IR film, but refuse to use a tripod to shoot with it. If anyone has had any luck shooting new IR at "high speed" ( said facetiously ), please let me know.
JP
JP
charjohncarter
You can use Efke IR820 at 25 with a 25 red filter, not much IR effect but that's up to you. I do use a Hoya R72 filter too, it is shot a EV .5 so tripod is necessary. I did this last week with the Hoya filter:
jpa66
Carter,
Great photo! Even though I'm wondering if the IR effect can still be had at faster iso speeds, I am curious as to how you developed the film.
sevo
Fokutorendaburando
Rollei Infrared 400 is considerably more IR sensitive (in sunlight around ISO 15-25 with a 690nm filter, where Efke is down at ISO 1-2) and has finer grain.
ZeissFan
To answer the question. You probably could shoot at the higher ISO and then pull process, resulting in a flat negative, which would then require compensation when printing or scanning.
Otherwise, no. A slower ISO is something that you accept when shooting with b/w infrared film. Even at ISO 25, you're still shooting in daylight at f/16 at 1/30 or f/8 at 1/60 or f/5.6 at 1/125. You should be able to hold a camera steady at those speeds.
robklurfield
eclipse
lovely image.
charjohncarter
Carter,
I don't know about faster ISO/EV but I use .5 or .365. I,if a half shade scene, do the old expose for the shadows and develop for the highlights. That sounds nutty because I never use a meter with Efke IR820. On the one below I think I exposed at F11 and 7-8 seconds. There is a fierce reciprocity failure after one second with this film so it is almost helpful because you almost can't over expose the shadows and even the highlights stop exposing:
charjohncarter
lovely image.
Thank you, I love this film. It is way smoother than HIE.
jpa66
So it's pretty much what I expected - there's no comparable IR film in speed to HIE. When the weather warms up around here ( like maybe in July... ) I just may try some of the new stuff, and break down and use a tripod.
Carter: the second photo is even better than the first. I love the look of that film.
drewbarb
picnic like it's 1999
This thread makes me think hard about those ten rolls of HIE in my freezer.
Anyway; not to hijack this thread, but what current IR film has the highest IR sensitivity? Anyone? I assume it's the Efke 820, which is indeed pretty slow, but are there any other decent options for IR these days?
charjohncarter
Freestyle has only 3 listed: Ilford SFX200, Efke IR820, and Rollei IR. The last two have the same sensitivity. Ilford is called near IR. You can get IR effect with an IR filter. I just use a red filter getting little if any IR effect.
Thanks for the comment jpa66.
robklurfield
eclipse
I like this one even better. really nice.
charjohncarter
Thanks robklurfield, some people think that you can't get shadows with IR film, but this gives them and it does it well.I like this one even better. really nice.
Chris101
summicronia
Way back in the days when film was used for astrophotography, one could 'sensitize' film with hydrogen prior to exposure, which provided several stops of sensitivity. I have considered using this process (if I can find - or build - the hardware!) with Efke Aura film to see if I could get a hand-holdable IR film out of it.
dovevadar
DoveVadar
Guys, what is a conservative iso grading for Rollei 400 with an R72 filter?
I'm always a fan of true IR b&w.
dovevadar
DoveVadar
"Almost" IR
sfx 200
sfx 200
charjohncarter
OK, I shoot SFX at 40 with a 25 red filter, Hand held but very little IR (which I do not want). Here is what mine look like. Maybe a little to 'dreamy' but I like it this way:
Tom A
RFF Sponsor
That works, tried it years ago. Much less harmful than "mercury Intensifing". You leave the film cartridge in a sealed glass container ( I used it with an old humidor) and a couple of drops of liquid mercury for 3-4 days - up rate the film about 2 stops and process quickly after exposure. It did work, at least with older, "thicker" emulsions. Somewhat unhealthy though.
Chris101
summicronia
Thanks Tom - I had forgotten about that! I'll give it a try. I ain't scared of mercury - I'm currently doing uranium toning. Now THERE is a heavy metal!
BTMarcais
I shoot SFX200 @ 50 with a 29 red filter. I like the results better than with a 25, and I can still handhold if necessary.
-Brian
-Brian
