IR in a Kiev II or 4a
colyn
ישו משיח
3:39 AM
I just came into possession of several rolls of frozen Kodak IR B&W film and was wondering if the Kiev II and 4a will handle this film without fogging etc..
It's good to see Russ's bits ;) but I would have presumed that anyway. That would be one real advantage to the type of back used by the Contax/Kiev cameras.
Pity I don't have any film to try it out... If you have the lenses, could you see how coated vs uncoated lenses deal with IR film? I love shooting old uncoated lenses so... ;)
William
It should work fine. There's metal all around and no LED film counter or anything.
Focusing wide open may be a bit inaccurate because the lenses don't have an IR focusing index (and with the 50 lenses the index would have to be on the body!).
William
I have a uncoated 35mm f/2.8 Zeiss Biogon I'll have to try out with IR..
Thanks for the replies I'll give some IR a shot :D this weekend..
This has inspired me to try some IR out in one of my FSU RF's, ive tried in slrs and found removing the filter to focus/compose very tedious.
IR was just made for RF's. Make sure you use a wide lens to get as much of the sky in as possible for maximum effect. Besides, if you use a wide lens focusing is not critical.
Russ Pinchbeck
