is it me or the x-p1?
back alley
IMAGES
11:54 PM
i can't get the histogram to show on the evf screen on the x-pro1 while i can on the x-e1...is that normal for the camera or am i missing something?
it shows on the rear lcd screen just fine.
It is a display value option
First make sure that the histo option is not disable in the display options sub menu, then cycle thru the display types until u are in custom display mode. Default is not custom mode when I get the camera.
Gary
I was just in a few days ago to compare both models at my local camera shop. The histogram could definitely be seen on the electronic viewfinder of the X-Pro1. So I know it will show up if the correct button/menu option is pressed.
Forgot to mention cycle thru the displays with your eye on the evf/ovf or else it will only do it for the rear LCD.
Gary
