Is this ground glass useable for film plane focus callibration? It's not flat.
Forest_rain
8:17 AM
I salvaged this from a broken Zenit E that I have. This is the focusing screen/ground glass. No markings whatsoever...there is also a little metal spacer that goes under (last picture). I'm not sure if I should use this or not.
It looks like the glass is curved on the top, perhaps to give it a magnifying quality? My question is will this give accurate focus for calibrating infinity focus with a loupe, or will this magnification throw it off.
Update: the viewfinder has a slight magnification to it. I removed it from the top plate, it has maybe 2x magnification. Perhaps this is designed to be used in tandem?
The only other flat ground glass I would have to scavenge from an extra retina reflex s with slightly off shutter speeds. Plastic focusing screen with split screen center spot.
