J8 - strange serial#
Igor.Burshteyn
3:22 PM
I have silver J8 with serial number 0162083. Looks strange to me - no trace of coating (and it does flare badly), but apperture ring has click stops. Any idea what year this one come from?
Shortly after I got my Kiev I read something about the odd serial numbers on some Jupiter 8 lenses (early ones I believe) but I can't seem to find the reference again. I'll keep looking.
Peter
A look on the Communist Cameras site came up with this quote
This is a 50mm F2.0 standard lens with apertures to 22. It focuses from 0.9 meters. This lens does not have a focusing mount built in. It is the most common lens found on Kiev range finder cameras. This lens is for the internal contax mount. There is also a Jupiter-8M which is modified internally but except for the marking and click stops, looks identical .
Kim
I have a silver (with black nose) J-8m in Kiev mount with aperture click stops, serial number begins with 58....
But you are correct, yours has a weird serial number!
maybe it's an early J8 ? as far as I know, all J8 were coated, maybe it's a frankensteinization of a KMZ ZK (sonnar copy) lens ? It might be possible that the lens has been assembled from other lens parts, but as far as I know, there are no click stops on J8's before the J8M.
//max
:)) LOL - "frankenlens" makes sense to me. I already have kiev4a with rewind crank and hot shoe installed from god-knows-what-camera. Works great - build quiality of early kiev 4 and ergonomics of late 4am.
Frankly speaking J8 looks more like lens from some pre-serial batch.
Its the click stops that just don't seem right on an ZK or Jupiter-8 (not 8M) lens. I recall reading somewhere that the 0 series were some sort of early production lenses.
I think these J-8 were mounted on all sorts of optical equipment, I came across one mounted on a fixed barrel with M42 mount that is attached to some sort of IR-scope as an eyepiece! So I would not be suprised if your lens left the factory that way, given that they would probably cannabalise overun parts from other production lines.
I think they even have one mounted on collapseable M39 mount. See link:
http://www.sy916.net/sy916/showarticle.php?id=1553
