Jobo CP tanks or similar
Rhodes
Time Lord
8:34 AM
I'm considering starting to develop color films and so I began on a "hunt" for a jobo cppa 2 or cpe tanks. But normally, the offer of this material is limited here and expensive (700€, for it is expensive. Had a bad luck of finding one cppa 2 for 200 but it was already sold:() and when looking in the bay, I got the same result: expensive (or due to big demand, prices rocket) or the seller do not ship to my contry.
I ask, and alternatives? I found some older model cpa that are not so "big priced". Is it good? Or there is some other alternative of other brand?
The best way is to look in Germany. A CPA-2 with elevator or CPP-2 is the best.
I found mine for zero euros but has been upgraded for a new elevator. So far it worked fine although the re-circulation pump is the weak part in a CPA. Also use the "easy roller" modification to keep the torque on the drive motor as low as possible.
Best regards,
Robert
Thank you! A found a cpe-2 and bought it. It was cheap but no lift. Possibly in the future I will get one!
