Jupiter LTM Jupiter 3 in need of aperture blade
Jupiter M39 lenses
smaphoto
4:02 AM
I have got a Jupiter 3 in need of some work. It only has 12 aperture blades rather than 13 does anyone know where blades can be sourced. Also I am having a problem unscrewing lens module , any tips would be appreciated.
If it's missing a blade but the aperture is otherwise working fine -- i.e., no loose blade floating around, aperture not jammed, aperture opens and closes throughout the range -- don't worry about it. You certainly won't notice a difference in the images, and the effect on through-the-lens metering will be miniscule.
David
