Kiev 4 Take Up Spools?
ryueikyo
Ryueikyo
3:29 AM
Does anyone know where I can get my hands on a four or five take up spools for my kiev 4's?
I have trie ebay, but have not had that much luck.
If anyone has any for sale plaese let me know.
R
They're quite easy to make from the central spool of a 35mm cassette - ask at a local 1-hr lab if they will let you have some.
Otherwise look up Alexphoto's e-bay shop (might be alex_photo or alex-photo).
Easy to make
Easy to make
R
I needed a couple of t/u spools for my Kievs so I copied the Contax design. Just get a hold of a few film spools, using a hack-saw cut a diagonal starting in the middle of the shank carefully down to the end of the spool. Use fine sandpaper to tidy the incision and to remove fine bits of plastic and voila! Kiev spool. Cheers from Australia
I made several from film spools I got from the 1-Hour place at Costco. I filled the center with plumber epoxy and did some cutting with a hack saw blade. Smelled like heck while it was drying but worked great. I gave all the ones I made away a while back. I used this link for mine.
http://elekm.net/zeiss-ikon/repair/spool.html
It's really easy to do.
B2 (;->
