Kiev 4 Type 2 take up spool
John Bailey
9:42 PM
I have a Kiev 4 type 2. The take up spool has a centered slit+metal clip to secure the film. I have to trim the leader or fold the film to fit. Is this the normal take up spool?
Thanks,
John
Hi John,
well I have a couple of take up spools like yours in my Kievs, and after examining the situation I decided to trim the leader and use it that way without problems. Curiously, the Feds-Zorkis all have a "normal" take up spool...
Another option would be to fold it, I suppose, but you can also build your own easy to load spool, this is a link to the how-to, part of the website of another member of this forum, ZeissFan.
http://host.fptoday.com/melek/zeiss/repair/spool.html
Best !
Oscar
I've never actually seen an orginal Kiev take-up spool. The only ones I have ever seen were adapted from film cassettes.
It's possible that what you have is the spool from a reloadable cassette. The center clip or slot is usually the hint that tells you it was once inside of a cassette.
If you use the link above to make your own from a disposable cassette spool it will be a lot easier to handle.
I have also successfully used the removeable takeup spool from an Exakta. You might have to remove the clip and reverse it since I think the Exakta takeup turns in the opposite direction.
-Paul
