kiev 4am/4m ease of operation?
John Bailey
6:20 PM
Is the film advance/shutter setting on the more "modern" 4am/4m easier to operate than the "older" 4/4a which I have? Smoother and less force required?
Thanks,
Actually if your Kiev has a harsh advance, you'd probably be better off spending the money on a CLA of that body rather than on a new one. Oleg www.okvintagecamera.com come highly recommended though I haven't yet used his services.
William
John Bailey said:
Thanks,
Pretty much the same although the AM is easier to rewind because it has a crank.
I agree with both W's... but note that the AM (am) is easier to load
with the fixed spool. That said, I use my older version more often.
None of these Kiev cameras are "easy" to wind when compared to more modern designs. They are a bit rougher than the comparable Contax models, as the gear trains are not as finely polished.
I found a huge difference between an early (1959) Kiev 4a and a later (1980's) Kiev 4am. The earlier Kiev was much smoother and more Contax-like in its operations.
