stephen_lumsden
Hi
The Kiev 4a seems to be shaping up ok.
Using a Sekonic 308s seems to work ok with it but sometime I would like a bit more of a mini setup.
Thinking of ordering a Kiev 4m from Yuri at fedka.com (his J-12 seem v.good so far, the j-9 stiil unsure about, but not enough pics taken yet to say good or bad..).
The advantages about the 4m seem to be:
Hot shoe:
Is this effective and can I use it with any flash, most likely the one which goes with ethe Canonet I have (forget the name but it is the Canon on which is suppoed to go with the Canonet)
Meter:
Fedka.com say it is working, but is it any good? I am not talking good enough for Slide here but print/bw would be ok.
Any ideas?
rgds
Stephen
Hot shoe:
Meter:
Any ideas?
rgds
Stephen
Duncan Ross
Say it with flashbulbs
stephen_lumsden said:Hi
Hot shoe:
Meter:
Any ideas?
rgds
Stephen
The hotshoe seems to handle modern flashes with no problems, certainly the flash contacts are substantial enough! My meter is always within a stop and there is a degree of adjustment under the meter knob. Mine gets a bit lazy as the light gets low though so I only really trust it for outdoor shots.
The jupiter 12 is a cracker. Here is an example using old-fashioned film;
http://www.rangefinderforum.com/photopost/showphoto.php?photo=12051&cat=500&page=2
I find the viewfinder slightly better on the 4M/4AM too, there is less of a letterbox to look through.
Good luck!
Duncan
newspaperguy
I'm a confirmed Kievoholic, but if you're talking "mini-setup",
You're NOT talking Kiev. When I need compact, I turn to a
Zorki 1 (or other bottom loader) with a J-12. If it's the meter
that's bugging you, take a look at Gandy's CV clip on. Much
more accurate than any old selenium IMHO.
Rick
Rick
stephen_lumsden
Thanks guys. May look for a 4m now as I do not really have the money for the CV clip on yet and cannot justify one at the moment. The J-12 is quite cool though, and while the Kiev is not the smallest camera in the world, I will use my Canonet for the smallest setup I have rather than go for another LTM Russian RF. When it come to interchangeable lens RFs, the Kiev is good enough for me right now.
rgds
Stephen
rgds
Stephen
V
varjag
Guest
Don't bother with Kiev's built-in meter. Use sunny16 rule or buy a cheap meter (e.g. Sverdlovsk-4).
pangkievrange
I'm a kiev rangefinder collector. For practical use, I take out Kiev 4m or kiev 4m (extra weight for low speed shooting) for shooting all the time. If the situation is more relaxing, I bring out kiev 3 or kiev 5 and fiddle with the loading procedure (Make no mistake, I use cassettes).The meter on my kiev 4m will give a kind of accuracy (1/4s at f/8, kind of struggling) and the response to strong light condition is not very linear (e.g., 1/500-1/1000 at f/8). I recently bought sverdlovsk-4 and put in 3 AA alkaline batterys. A very accurate meter (self-calibration!!). I like the incident light function.
pangkievrange
pangkievrange
V
varjag
Guest
Yep, Sverdlovsk-4 is a nice and useful gadget. Got one for my friend, would buy now for myself too.
And for the extra weight at handheld shooting I use universal finder on my 4A
