arri
I like the Ektar lens and that's why I removed the lens cells out of the Retina II and mounted 'em into an aperture barrel and calibrated the distance between it and checked the concentricity.
I used a Russian Industar socket. It has to be disassembled, cleaned and calibrated.
I turned an adapter ring with the correct length and adjusted the rangefinder cam.
Final check with an autocollimator and then tested with my Leica IIIb and film.
Everything is screwed, nothing glued. All parts made of brass.
Very interesting is the extreme sharpness when I use it with film and the creamy softness with digital cameras.
The colours are reduced.
A very interesting lens and a very rare as well.
Kodak Tmax 100, Wehner Developer
and a sample made with a full frame digi cam
