Konica Hexar RF Experiences?
Kumachrome
11:34 AM
Hello all, I'm considering getting a Hexar RF. I've heard some great things about it and some not so great. I wanted to know how its reliability is and how your experience was.
How long did you have it? Do you still have it? Did it give you any major issues? Assuming I treat it nicely, and don't abuse it too much, do you think it should last me a long time?
I read that if the serial number is over 144xxx or something like that, it should be fine. My main concern is that I don't want it to become a paperweight and give me an error code just because I looked at it funny after a month.
I know it's not a Leica and I'm not looking for Leica qualities in it. I own an M4-P and am not looking for a second Leica body. The main things that are selling me on the Hexar are:
- Great match for my Hexanon 50mm f2 lens
- Looks nice
- motor drive
- 1/4000 shutter speed
- AE mode
- rangefinder
Thanks for sharing your experiences!
I loved my Hexar RF. I had it for a few years between 2008 and 2011. It was as reliable as a Nikon F4 which is to say it never failed. I sold it, like all the other gear I've owned, because I needed the money. It felt like the camera that the M7 wanted to be, modern. I wouldn't hesitate to use another one again.
Phil Forrest
Mine still works well, though it hasn't seen heavy use. The viewfinder is a wider view, .60 magnification if I recall correctly, and that works really well with wider and normal lenses or if you wear glasses.
The batteries are a bit of a pain, but you do get the built-in motor drive and AE. The motor drive allows you to easily keep your eye up to the viewfinder between shots.
The build quality is, at least to me, up to Leica quality. Feels a tad lighter than a M7, but that's the titanium. Mechanically it's easy to maintain. The top plate comes off nicely for rangefinder adjustment.
If you decide to use it, then just enjoy it and stop worrying about the electronics. The chance of one of the dreaded error codes (i.e. 11, 13 and 20) developing seems to be random. It can be the next day or never.
I have a friend who had an irreparable Hexar RF (error code 20) but loved it so much to the point that, he's currently on his second one. That's what I'd call a love affair...
I had one for about seven years. I got the rangefinder calibrated at Precision Camera right when I bought it, and never had any problems afterwards. I loved that camera but sold it to fund a Leica MP because it became impossible to repair. I still want it back for the lower magnification viewfinder (I wear glasses and like 28mm more than 35mm), beautiful design and great build quality, metal shutter, AE, and easy film loading.
Based on my experience over 5 years or so, I would recommend one without reservation. Have had no issues using Leica lenses on it either, tales of the Hexanon RF mount to film plane apocalypse notwithstanding. YMMV.
Some likes it, some don't. Put me in the like it, no worries column. Relative to my M2, it, for me, falls short nowhere, and excels in several known areas. Oh, forgot, it's not a Leica, there's that, and that bothers some people. That gnawing feeling deep down inside you when you hold it to your eye, that knowledge that you are not holding that thing in your hands that somebody who opinionates for a living says is "iconic". The Konica Hexanon RF, it's not iconic. Superb camera though, maybe that can compensate.
I bought one off eBay a few years ago and had to return it because occasionally a frame would come out completely blank. A nice machine but, given my previous experience with a Hexar AF, which had a similar issue, I went instead for a Zeiss Ikon which I still have. If you buy one, make sure you can send it back if issues arise on testing.
I had one years ago that had many issues with the RF alignment that nobody in the US seemed able to fix, something about needing to have the proper 50/2.0 Konica lens to do an alignment? Sold that one after sinking a bunch of money into it trying to have it sorted. I can't seem to find the thread about alignments on the Hexar now. This was back in '08 or so.
Got another one four or so years ago for a particular project that needed the high shutter speeds, and wasn't able to get along with the lack of the hand wind, so sold that, but have another one now for a few years. It doesn't get a ton of use, but both these have been without any issue. Sturdy and robust, much better in the very cold than the M7. I tend to bring it when I'm going to be working with only one body away from home. I can load it up with some 400 and even work in sunlight.
I used two bodies and a few Konica lenses for over a decade. Never had any issues with them. Traded the bodies for an M9 a couple of years ago but that's another story. I still have the lenses and use them on my Bessa T.
Good luck,
Lou
Konica Hexar RF Problem
Found this thread after just experiencing a problem with my Hexar RF. While exposing a roll of B&W a few weeks ago (after a long period of non-use), the camera behaved very erratically; as I recall, display number in frame counter window jumped ahead - don't know if new number was displayed - then film rewound. When processed, lots of blank frames resulted. Inserted an old expired roll to test the camera. I fired several shots a day for several days; film counter advanced normally. Then today, after firing several frames, the frame counter in window reverted to zero, and the film rewound before end of the roll. I'm afraid I have an expensive paperweight. From what I've seen on the web, I don't believe they're repairable; parts supply is nonexistent I've read. Does anyone have any ideas or suggestion? Does anyone repair this camera? I'm reverting to my trusty M6 and Minolta SR T's. Thanks for any inputs.
I’m among the No Problem cohort here. I bought mine at a fabulous price here 5 or 6 years ago, in part because it had a -3 diopter. Hexar diopters of all strengths are nigh impossible to find, so even if I were inclined to sell it, I’d have to find an equally blind beggar who likes to shoot without his glasses. But I have had a great run with mine. It doesn’t have the ZI VF, but 1/4000 is a delightful option for fast lenses in daylight, and not having to wind on and recompose your horizontals /verticals is neato. Why, it’s almost like a Contax G—without the awful VF or the missed focus at f2...!
I bought one about 10 years ago and ever since it has been the camera that I use the most. Never had a problem with it and it has been hammered. Before I got it I had read about all the "issues" with it including the rf going out of alignment. I popped the top and put a drop of canada balsam on the wheel thingy and it has stayed in alignment all these years. The paint is worn off of all the corners and is completely gone from the on off switch. Still works perfectly. Gotta love Titanium covers... Masked over the 75 and 135mm framelines too so the finder is niiiiiice and uncluttered. Only issue I have with it is the slight shutter lag. All cameras have a bit of shutter lag, but for some reason small electronic cameras of this type have more and the Hexar is no exception. No idea why.
I think a lot of the early naysayers were just Leica freaks snobbing out. Or was it Leica snobs freaking out? Lol.
I owned one for a while and never had any problems, but then as I said, I didn't have it for long. The viewfinder is a little dimmer than a Leica (what isn't), but it's fine, and eyeglass wearers will like the .60X factor.
It's not that anything was wrong with mine, but it felt sort of "dead" in my hands. I know that may sound odd, but it's an all electronic camera, and the knobs and such don't have the same tactile feel of a non electronic camera. My Bessa R2A and R3A cameras provided more feedback to the user, probably because those cameras had a manual film advance.
Sorry if this is not a lot of help to you. I suggest trying one before buying if at all possible, or buying one at a good price and reselling it if it doesn't work out for you. It may be exactly what you're looking for. I had the same complaints about my old Hexar AF too, along with not wanting to have that much money invested in an all electronic camera with a fixed lens, especially one that was wider than I normally shoot.
Dennis M.,
Have you tried cleaning the battery contacts and new batteries? Sounds as if it might be temporarily losing power.
You could keep running that junk roll through repeatedly to see if things loosen up.
Good luck.
Hi everyone, so I ended up getting the Hexar RF and I'm loving it! As many of you stated, the rangefinder was out of alignment when it came. It was super easy to adjust. Just had to remove 4 screws and the ISO dial rentention screw and the top place came off easily. Then, adjusted the rangefinder and secured it with non-permanent lock-tite. While the top plate was off, I dusted the viewfinder and all that too and made sure the electronics were clean, blowing off any dust that may have been on them.
The next day, I began shooting it but ran into an issue, which I believe some of you have reported as well. Here's how I fixed it:
1. remove the film, clean out any dust in the film chamber.
2. With a Q-tip or something thin, apply a small amount of rubbing alcohol to the Q-tip and clean the electronic contacts inside. The DX sensor, and the 3 contacts located right under the film curtain.
3. Now, open the battery chamber. Clean the battery chamber cover with rubbing alcohol. Make sure there isn't any dirt or corosion on it. Clean it even if it looks clean.
4. Clean your batteries if they're old.
5. Dust out the battery chamber, make sure it's clean obviously.
6. This is the big one, and I think it's the primary culprit: Ensure that your batteries are actually making proper contact. I believe the issue comes from the camera being jostled about as you walk around and such. If it is jiggled the wrong way, the batteries may lose proper contact because they may move inside the battery chamber. In my camera, it came with 2 batteries from 2 different brands. Therefore, the little nibs at the positive ends were slightly shaped differently. I flipped the order of the batteries and this fixed the issue. By this, I mean the batteries were ordered like "duracell first, then energizer." So, I put the energizer battery first, then the duracell battery.
I now have no issues with the camera! Hope this helps!
Konica Experience
Konica Experience
Konica made some impressive cameras. I owned and used quite extensively an Auto S3 (back in the 1970s) and an AF (in the 1990s). I also briefly used an RF (see post above). The issue I had with them is that they could be unreliable.
The Auto S3 was a terrific little camera with a superb lens and interesting fill-flash capabilities but unfortunately the frames started to overlap, so I had to move on. I wish I'd known at the time that this was relatively easy to fix and was the result of the rewind crank requiring lubrication.
The AF also had a wonderful lens and was very quiet and reasonably compact, for which it was worth putting up with the strange little buttons on the top plate. However, like the RF I tried, it started to produce blank frames so it had to go.
It seems that some users have been lucky and I envy them. If these cameras had worked reliably I would still be using them because they provided a combination of features not found elsewhere. In any case, if purchasing an AF or RF today I would urge caution unless you're good with electronics. The Auto S3 is probably more easily repairable and I wish I'd kept mine.
