reptkeu
Hi everyone,
Are there some Konica Hexar RF users around here who have encountered problems with light streaks on their film?
It is the second Konica Hexar RF I have with this problem. It doesn't do it on most frames, just on some of them, and usually about 3 to 5 in a row, ewith some frames more affected than others.
Below are some examples of affected frames. Any suggestion as to what the issue might be and how to fix it?
Plungefrog
I don't own one, but I would suggest checking the light seal surrounding the film cassette window on the back.
Huss
is the film bulk loaded? are you developing it yourself?
wwfloyd
This looks much like a shutter flaw that I recently saw in a new-to-me Pentax K1000. About 1 in 5 frames was affected, and shutter speed did not seem to matter. The K1000 has a horizontal focal plane shutter, and, the explanation that I read was that one shutter curtain was dragging a bit, due to a worn gear or spindle.
But... I think the Hexar RF has a vertical shutter, so, I guess that type of effect should occur horizontally. I throw it out there, in case I'm missing something that might make it directly comparable.
Geo Toreno
The problem is probably a light leak around the foam rubber seal surrounding the film check window in the camera back. You can check by covering the window with black electical tape and shooting a roll of film for test.
