Konica II hood
cloud worlds
2:04 AM
Hello,
If you shoot a Konica II, I have a question; what do you do for a hood? What type of hood do you use (screw in or push on), and what size hood do you use? Now that I've received the camera ( I like it a lot) I'm guessing the filter size is 24mm but not sure.
Thanks
Do you mean that you use one hood for both cameras, or do you have a different size hood for each camera? They work with a screw knob, don't they? The lens diameters of the II and III lenses are quite different, and I imagine if using a single screw-on hood for both that on the II, there might be a serious gap in the back.
Thanks
It could be I and II then. The hood has a screw. I have one Koni Hood that fits two Koni models.
