Konica S2 Repair Webpages?
kievman
Kievman
5:19 PM
I have a S2 which has a cloudy viewfinder that needs to be to cleaned. If any o you f folks know the links to those konica repair pages. I would certainly be very thankful if you could post them here. -Thanks a miillion - Michael
Kievman, removal of top cover is easy - unscrew flat-headed screw on advance lever and one or two screws on sides, rewind crank unscrews in standard way - put something in groowed end and rotate top part.
S2 even has screw-tightened metal shield over RF glass instead of standard for this class glued black paper. This is well designed camera.
