L H 2 hood?
ChrisPlatt
Thread Killer
9:20 AM
I have a Bessa R body with 35/2.5 Color Skopar lens.
I've been thinking about getting the Voigtlander LH2.
Has anyone out there used this combination?
To what extent will this hood block viewfinder?
TIA,
Chris
With the lens set at closest focus and the 35-90 frame-lines in view, the left edge of the hood at the bottom of the viewfinder is in line with the left edge of the rangefinder patch horizontally.
The left side of the hood curves up to the bottom of the 90mm frame-line, in line with the right side of the rangefinder patch.
From this point the top of the hood is seen as a straight edge to the right side of the viewfinder.
The hood intrudes less when the lens is focused at longer distances.
Thanks very much for checking.
Beyond what distance would you say hood no longer intrudes, or not objectionably so?
If it's not a big factor at normal working distances I will take a chance...
Chris
The hood intrudes throughout the focus range. At infinity, the top edge of the hood is further down, about half-way between the bottom edge of the 90mm frame-line and the 35mm frame-line. The left edge of the hood is about the same distance further to the right. Using the rule of thirds tic-tac-toe box, the hood compromises the bottom right corner. If you compose with this block, you may need to fish around a little with the finder to compose there.
I don't actually use the hood with the LTM 35/2.5 Color Skopar very often as the flare monster hasn't bitten me with this lens, one of the things I really like about it. I think the last time I used it and the 35/2.5 was for a slight mist/drizzle. Has the flare been an issue for you with the 35/2.5 Color Skopar? If you want the hood for protecting the front lens element, it'll certainly do that better than the tiny ring the lens cap goes over.
What prompted me to get the LH-2 was its sibling lens, the 50/2.5 Color Skopar. With the sun low in the sky on a 4th of July, the flare monster got me. In retrospect, if flare was going to happen, that was the time. Once bitten, twice shy, though. Nonetheless, with the 50/2.5, the intrusion of the LH-2 into the 50mm frame-line is truly negligible.
