Labeling Tip
Jeremy Z
3:24 AM
In various threads, I see folks talk about labeling cameras, film canisters, bulk loaders, etc. with masking tape, blue painter's tape or even paper labels.
The problem with these is that they either degrade and leave a residue (masking, paper labels) or don't stick well. (blue painter's tape)
My recommendation: buy a roll of yellow or white 3M electrical tape at Home Depot for a few bucks. The adhesive holds up well, it's relatively inexpensive, but doesn't leave residue when removed. Mark on it with a Sharpie.
I have used black narrow Dymo tape for years without problem. Stays on, but peels off without a leaving a residue. I also have used Scotch "Decorate and Repair" Tape to color-code equipment. Comes in wide range of colors and usually has not caused a problem with stickiness or removal. However, I did find that it degraded the chrome on a prewar camera. Pre-WWII cameras did not have the same thickness and quality of chrome that post-war do. I am more cautious now. No problem placed on black painted surfaces. Your mileage may vary. WES
I have always found electrical tape to leave a healthy amount of residue.
Gaffers tape is slightly better but still leaves some tack.
Avery Re-Usable labels come in a few sizes and will not leave residue but I have found their adhesion can leave you wanting something a little stickier for those permanent applications.
Whatever works I say!
Brother P-Touch label maker, various sizes and colors. I have used them on mail boxes and they have held up for years. Have one on my GFX that says "Check Settings". I left out "Stupid".
Ultra-fine tip Sharpie pen stays in my camera bag to label film cans and rolls.
Several 6 inch (15cm) strips of gaffer tape are wrapped around the pen just in case I need some tape to improve grip on a body or something loose in place.
Sent from my iPhone using Tapatalk
I usually go with Tamiya Masking tape.
It's a bit more expensive but it's tacky enough I can use it to hold the film when bulk loading, but also doesn't leave residue no matter the storage conditions from it's intended use for scale models.
I haven't had any trouble with 3M masking tape. Blue for Velvia, tan for black & white.
If you use tape on your camera and find it too sticky There is an old painter's trick you can use. Quickly drag the adhesive side of the tape on your pants leg. This will help reduce the stickiness of the tape as well as the residue that can be left behind.
"Drafting Tape" is another alternative. It is a thin and flexible tape that is designed to hold drawings, blueprints, or tracings to drawing boards. It adheres well and removes easily without residue or damage.
Hope it helps!
