Bill Pierce
Why do teachers of photography often start their students with film cameras in the day of digital? In the long run film is more expensive than a memory card, and even if you are shooting black-and-white and processing it yourself (much less sending color film to a lab), there is considerable delay between shooting and seeing the results. And, at least in terms of the small cameras that most of us use, today’s digital cameras can deliver a technically superior image in terms of sharpness and tonal range.
I think the answer is relatively simple. Film slows you down. It’s somewhere between difficult and impossible to blast off a huge number of frames with the hope that one will be OK. (The ultimate slow down is a sheet film view camera.) ’Nor will you see that image right away and be able to correct the mistakes you’ve made with a second attempt. You really have to run a tech check in your head. All in all, you have to think more just to get the picture to come out.
To me, the sad thing is that the photographer who works in a technically optimal way, composes well and then pushes the shutter at the right moment when he works digitally often backslides. For me, it’s think film, shoot digital.
Your thoughts?
Your thoughts?
