Front elements
Front elements
Hi, did the same job last week end, but couldn´t get into the rear elements.
The front is easy:
Remove the screws retaining the aperture ring, take care with the coil (long thin flat one), previously set ap to 3.5.
Immediatelly you´ll notice three tiny lateral screws wich set in place the lens assy to the filter rim.
Once out unscrew gently the rim and everything will be out.
The front lense will be exposed, to set it free you must loose it by gentle blows and gravity.
Once the first is out, you´ll notice the second one and a threaded rim surrounding it, that lens is NOT screwed it´s set as a sandwich.
Take it apart grabing the rim. Once done you´ll reach the ap blades.
Take good care not to get the blades out of place, because in a large lens is easy to put them again in place but in this one uffff, thankfully i did ok and the blades never dropped out!
Bye
