Leica 50 summilux pre asph PROBLEM?
Dan95
1:02 PM
Hi recently I bought a Leica 50 lux, second version. Had a filter on, and I tried to remove the filter. Instead, the lens detached from the barrel *too much force I guess
I was able to screw the lens back in. Is this normal ? Or should I be worried ? This also happened to my other 50 summilux v2.
And, when rescrewing the lens back in its barrel, do I need to follow any guidelines ? There are number etched in the barrel. I simply screwed it in till it cant be screwed anymore..
When rescrewing the lens, just screw it in till it cant be screwed anymore ? I screwed it back in till the dot is aligned with the aperture dot..
It should be tight. If the dot doesn't line up when tight then rotate the lens and try a different thread starting point.
