Leica adapters for Fuji X cameras
MiniMoke
8:04 PM
Which one do you deem the best M adapter for the Fujis? Original Fujifilm or Kipon or.... There are lots around?
Then again, for my LTM lenses, should I use a dedicated second LTM to X adapter or just put an M39 / M adapter ring on those lenses and use the 'normal' adapter?
For the moment I have a Quenox adapter that does it's job, but not much more. It seems a little bit wobbly, and if you put on the lenses with just a bit too much force, it overshoots the locking position... Not good!
I sell the Rayqual
because I think they are the best
1) precision fit and finish
2) correct infinity focus - something the fuji adapter does not have
3) compatible with more Leica M lenses than fuji
4) does not have the proprietary Fuji electrical connections
that is why the throat is wide enough to be compatible with more lenses
a new version with Tripod Mount will soon be available
likewise a Nikon G lens adapter, with and without tripod mount
see http://shop.cameraquest.com/rayqual-fuji-x-pro1/x-e1-lens-adapters/
Stephen
I sell the Rayqual
Stephen
Im looking into this myself, why wouldnt the fuji one focus at infinity? The adapter is supposed to be made just for that purpose?
the Fuji adapters focus PAST infinity
which makes them harder to focus fast
with super wides.
Rayqual adapters are spot on infinity.
Turn the helical to infinity and you are there
you don't have to tweak it BACK a bit to infinity.
1st reported by Sean Reid
Stephen
