Leica CL rangefinder full-range adjustment
antver
11:27 AM
Hello to everybody, and sorry for my English. I have recently bought a Leica CL which definitely needed CLA, so I opened it, cleaned and lubricated it, and solved this way a shutter problem (1/60 shutter speed sometimes worked in a wrong way - as "B"). But I still have a question concerning a rangefinder full-range adjustment.
I have already found two horizontal RF adjustments: 1) an eccentric screw under small plastic cap, and 2) an eccentric screw inside RF roller. There is also one vertical adjustment (under plastic cap). Still, even using all these, I couldn't adjust RF in a full range - if it's OK at infinity, it measures with errors at 1 m, since the adjustment range provided with the roller screw is not wide enough. Does anybody know if there are some additional adjustments for RF lever length?
Thanx in advance.
