archive59
Is there any legitimate reason for a Leica III having a seven digit serial number engraved on the top plate? No. 1524xxx
Thanks,
Mark
Thanks,
Mark
David Hughes
David Hughes
Interesting, especially as, if it was just 1524xx, it would be a 1935 model III but I expect you've realised that...
Regards, David
Regards, David
archive59
Regards, David
For some reason I hadn't thought to look up that number :bang: I had looked up the serial number without the leading 1. Your suggestion makes far more sense. That last digit is a 0.
A bit of background on this camera. It was sold as a Leica copy, but if it is not a genuine Leica, it is a fake as it has Leica engraving on the top plate. It appears to be in a quite bad state of repair with an aftermarket flash sync plate mounted on the front. To my untrained eye everything indicates a genuine Leica except for the serial number. It has a slow speed dial, the lip on the viewfinder window, round rangefinder lens cam, and strap lugs.
Dralowid
Michael
If in doubt post a picture or two, you'll get plenty of feedback
Michael
Michael
archive59
archive59
archive59
archive59
archive59
michaelphoto
Another screen grab.
I believe that Leitz would be able to spell Wetzlar in a correct manner.
Mark Wood
"Modified" Fed (not Zorki) with a slow speed knob stuck on?
Livesteamer
Looks Russian to me. Joe
Mr_Flibble
In Tabulas Argenteas Refero
I missed that on the first pass :bang:
But yeah, the whole finish of the camera screams Soviet Copy to me.
archive59
I think that it is an 'e' and just the low res picture distorting, but you could be right.
archive59
It does to me, but all the specific obvious signs (except the serial number) are for it being genuine, or someone has put more effort than usual in to obscuring the original camera.
Dralowid
Michael
Do the slow speeds work? IE are they actually there? This will tell a lot.
No diopter adjustment on rangefinder, ie it could originally be FED
Top housing and engraving looks very odd indeed
Shutter dial looks wrong, numbers wrong.
Covering?
Better pics would help but from these it looks like an 'assemblage' of some sort
With apologies
Michael
Covering?
With apologies
Michael
rgraphex
I seen that one first I thought it was fed around the viewfinder it certainly looks like one. Then I thought it looks a lot like a leotax no eye correction but still has slow speeds. I think the lens may be a real elmar. I passed on the bidding for that one.
archive59
Covering?
With apologies
Michael
All good questions, but I'm afraid I cannot answer them.
I should probably find something more productive to waste my time on, but I do find the whole fake Leica subject very interesting. The immediate telltale signs of a fake do not seem to be present with this camera. I have never really understood the economic drivers to produce low value fakes, but if someone is prepared to go to these lengths then I'm sure they will turn/have turned their attention to higher value Leica.
You are right, the numbers on shutter speed dial are strangely skewed.
Mark
Mike Fish
Mike in Sacramento
the flash shoe?
the flash shoe?
I seem to remember someone once pointing out that on "real" Leica's the flash shoe attaches with four screws vs three on the FSU cameras.
mike
the flash shoe?
mike
Mr_Flibble
The Leica III (and the IIIa) has 3 screws holding down the accessory shoe and the shape of the shoe with the little lip at the front is correct for Leica.
Bottom plate and internals seems to match closer with my IIIa, not so much with those on my FED NKVD.
But as said, it's missing the Diopter Adjustment.
Replacement top cover perhaps?
