Leica LTM Leica IIIC body covering material
clicker
3:50 AM
Any suggestions on where to purchase original body covering material for these older type Leica bodies.
Thanks
CRR Luton (UK) can provide 'exact' reproduction coverings for Leica's. It's not something you can apply yourself, however.
You can also presumably get it from Solms, or from Leica service in whatever country/region you live in.
Per Leitz the original vulcanite covering is no longer available.
There are others who make leather coverings for the Leica. cameraleather.com and Aki-Asahi are two good makers..
So what is the "vulcanite" that costs so much on an a la carte Leica M?
Oops here's the important details:
We can recover your Leica M ( non-metered ) or screwthread camera with EM vulcanite for GB pounds £ 95
You may think that £ 95 ( GB pounds ) is expensive to recover your Leica , but the job takes a number of hours to complete and entails dismantling and recollimating , but you do receive your camera back looking exactly as it should do . If you want a less expensive alternative , Fargo Enterprises sell a self adhesive vinyl that is very good . You will have to cut this yourself and for US $ 25 plus postage it is probably the best you will get for the price . There is enough material to allow for errors and you won't have to dismantle your Leica !
Ash said:
There you go colyn :)
Real vulcanite for the screw Leicas is not available. There is however aftermarket materials..
Actually I was referring to vulcanite for the screw Leicas..
