bence8810
Hello there,
Have acquired a Leica Summitar 50 lens on a local Japanese auction site and it conveniently came with a Leica IIIc camera. The body is pretty beat up but is very clean internally. While I can't quite inspect the speeds as the back doesn't open and my optical meter isn't useful here, I think it's quite alright. I did measure with the iPhone meter "shutter speed" but wasn't able to use the Photoplug with it unfortunately, just the mic based test.
In any event, I have shot a test roll and am looking at the images currently. I am no expert and therefore turning to you for help if you would be so kind.
Attached is the first roll's contact sheet that I scanned in at low res (300dpi) which I do in fact for all my rolls. I'd be very happy to scan some images in from the roll you think could help determine the quality of the lens. I bought this set for the lens only so I could use it on my M3 body. When doing the flashlight test as it is explained by Ken Rockwell, I do see a lot of Fungus in the lens, at least I think it is fungus.
I then opened up the lens as explained by Justin Low and have cleaned the two surfaces I could get to. After assembling, it is still showing quite a fair amount of "something" inside, didn't change for the better or worse as far as I can tell. Tried taking a picture of the lens but I couldn't quite get it while sending the light beam through it. I only have an iPhone in terms of Digital and it couldn't cope with it.
Thanks for any help and please let me know if you'd like me to scan in any of the frames from the roll.
Ben
Link to Image (large-ish)
Above is the link to the image. I have increased the contrast and brightness as I tend to scan flat. If this isn't good, I am happy to change the image in whatever way. The original tiff is flat. I can also scan individual frames if that helps. Really appreciate all the help!
Ben
