Leica M ever-ready cases
ChrisN
Striving
3:33 PM
Will an M4 fit into a case designed for an M3? I'm after a case, and all I can see is M3 and M2 cases. Thanks. If you happen to have a spare one lying around, let me know! :)
I have a M6 in a M3 "everyready" case and it will fit if you stretch it a little. The lugs for the camera strap are in a slightly different location and the metal sandwiched between the velour and the leather has a small indent for the lugs of the M3. For what it is worth I found a ratty case (for 5.00) removed the front and only use the other half of the case, then I sold the nice complete case I had because it is just more trouble than it was worth... literally.
