Leica M3 Industar problem
qhoti
6:24 PM
Hello everyone!
I've got my first Leica, an M3 DS ex condition from KEH.
I had an Industar 26 M and an Industar 50 collapsible so I ordered an adapter from Fedka. first of all the I-50 doesn't fit because the focus lever cant go past the lens release button shield of the m3.
I guess I'll be shooing with the I-26 for now but when I focus to infinity the focus is off by maybe two millimeters.
any suggestions?
Thanks
You can easily unscrew the infinity lock or file down the adapter ring.
It's not supposed to focus right since the flange distance on Leica / USSR is different. Then again; the adapter might be wrong thickness or the camera might be in need of adjustment.
Many variables to be considered with lenses from USSR and Chinese adapters ;)
I've decided to recalibrate the rangefinder, I searched and found the repair PDF, so far I have fixed the infinity focus but the 1 meter is off, I'm having a hard time turning the 1 meter screw. I don't want to damage it.
What makes you think that the RF needed to be recalibrated?
calibrating M for FSU-lens should be last option. sounds like something is going horribly wrong here...
FSU lenses aren't fully compatible with Leica bodies. You cannot get both 1m and infinity to get a match with the RF. How did you do the calibration, and do you have a link to the repair PDF that you refer to?
I agree. Don't alter the M3. Buy yourself a lens that is already compatible with thwe M3, nlikle a collapsible Summicron, or a CV lens, or Canon, etc..
here is the link to the post with the pdf:
http://www.rangefinderforum.com/forums/showthread.php?t=104743
I suppose you all are right, I only turned the infinity adjustment, I haven't touched anything else. I emailed David Yau who leaves here in Toronto. I apreciate everyones advice and concern, it's good to know I can receive help when I need it. Thanks.
