Leica M7 battery cover
sergiojaenlara
Rangefinder rookie
1:01 AM
I have several complaints about leica m7 battery cover position.
If you have the camera in your hand almost always like me, the cover contacts permanently whith the hand and it usually opens leaving the batteries to fall.
Have you any trick to fix this problem? The cover is loose and I put tape on it but it doesn't look very smart.
The covers on the two M7's I have lock securely in place. I would agree that either a replacment or an adjustment is needed.-Dick
The same thing happened to me me once in Europe. The battery cover fell off my M7 into a small drainage grate. I had to stick a piece chewing gum on a pencil and finally fished it out after about 20 minutes and several attempts.
