Leica M8 framelines
Vobluda
11:08 PM
I have an M8 framelines question:
Are the M8 framelins already counting with crop sensor?
For example if attached on M8 50mm Summicron does it takes up 50 and 75 mm framelines and are the 50mm framelines in this case counting with crop - aprox 65mm view?
Thank you in advance.
The frame lines in the M8 show a bit less then you see on the LCD screen. You put a 50 on the M8, 50 and 75mm frame lines show, corresponding to the sensor crop.
