Bill58
Native Texan
I read somewhere that it was generally NOT a good idea to mix brands of body/ lens. Is that true? What has been your experience w/respect to LTM, especially Canon body/ Leica lens?
kbg32 said:In respect to LTM, all work fine irregardless of lens/body combinations.
rogue_designer said:Except for the rare few incompatibilities (ie. the Jupiter Biogon clone that can't be used on the Canon P - due to a baffle/lens hit).
I don't see any reason not to combine brands of lens and body - for me one of the more attractive things about the LTM/M lens lineup is that very flexibility.
Stephanie Brim said:I keep on missing out on a lens...an interesting Japanese copy of an Elmar. If I had some money I'd be tempted to buy the thing as it's being listed for around $50 and apparently is rather good...but I have other things I need. Like the stuff to make the Lulu costume I'm going to have to work on all month. And I'm talking about Final Fantasy X's Lulu. If you know what she wears, you'll see why I'm going to be banging my head against a brick wall quite a bit.
jlw said:What, this Lulu?
Yeah, I could see how that would take a bit of time. And a lot of belts. If you're planning to wear it to a Halloween party, I suggest drinking moderately at best, because if you were to fall down the stairs in that outfit, there'd be no way to save yourself!
Be careful out there...
Incidentally, I assume that thing she's holding is one of the voodoo dolls she uses to kill people...?
Stephanie Brim said:I like the LTM cameras so much because of their incredibly wide selection of lens choices. It's also why I have a feeling I'll eventually have an M body: being able to use both M lenses and the screwmount lenses I have with adapters is about the ultimate for me.
rbiemer said:On the other hand, I need to be careful about which lenses I use on my FSU cameras: the RF cam in the camera isn't a "roller" but a triangular shaped cam. Not a big deal on most lenses BUT those lenses that have a focus "tab" rather than a "collar" apparently will hang up on the focus cam in the camera body.
physiognomy said:ps... In all seriousness, as others have stated, most (nearly all) LTM lenses will be fine on any Leica body... The only exceptions I am aware of are with the collapsible lenses & J-12/Biogon with the CL/CLE... Might also be a problem with the M5, but I have no business whatsoever using the 'L' word in public...
Anders,AndersG said:This is not a total show stopper - at least for some "tabbed" lenses and FSU cameras it is still possible to safely mount and dismount the lens provided that it is set to its closest focus distance (to retract the tab as far as possible). My new Canon 85/1.9 works without problems on my Zorki-6.
However, be very careful if you decide to try this - if the follower gets snagged the RF alignment is likely to go bad and you'll have to access the RF-follower through the shutter from the back of the camera to get the lens off.
Anders
wlewisiii said:Certain J-12's - they seem to be only those made before 1957 - have a wider rear element and won't fit on the later Canons (V,VI, P, L & 7). Ones made after that will fit quite nicely. I had one on my Canon 7 and was quite happy with it.
wlewisiii said:How do you know w/ certainty that it's a late (after 1957) J-12? Is there a serial number / color, etc. that puts it into the "later" category?
Bill
